Re: dwell setting
Posted by Samuel Chapman on July 22, 2008 at 19:52:48 from (72.24.5.97):
In Reply to: dwell setting posted by Samuel Chapman on July 19, 2008 at 09:20:02:
Thanks Guys, I've set the points @ .020 numerous times but my shaft must be worn worse than I thought because it changes after I run it then check it again. I was setting points on cars when you had to, so I've had plenty of practice. Anyway, I finally got the dwell very close to 60^ and it runs pretty good. I also ordered a shaft, bushings, and an electronic ignition. Thanks again, Sam Lone Jack, MO
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
