Mechanical (blasting, knotted wire . . .) removal will obviously dull any galvanizing that might be left on them as it takes the yellow off. Chemical (oven cleaner or other strippers) will react with the surface enough that it might leave it clean but I wouldn't count on it being shiny when you're done. More likely, you'll have a varied, spotty finish that relates to the varying thickness of the yellow over the zinc.
If you're really intent on shiny galvanized, I'd try chemical removers first. Potential problem there is that the corrosives in the cleaner will show up any place where the zinc has worn or scratched through to the steel. If you were to get lucky and find the zinc pretty much intact, you could lacquer it to make it shiny and pick up the flaky look of the zinc. (It does look nice.)
Were it mine, I'd clean them up well and put the dull aluminum paint to them. The costlier alternative is to have the shop that will hot dip them clean them up and do the job.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
