Posted by ScottyHOMEy on July 22, 2008 at 21:16:16 from (70.105.230.3):
In Reply to: h farmall posted by gary whitlock on July 22, 2008 at 20:14:21:
What manual did you get?
The service manuals (IH Blue Ribbon Series or the I&T IH-8) are more technical service manuals, and don't really address day-to-day maintenance. If you want to adjust your valve clearance, or shim the gears in your tranny, those are the books you'll need. For this kind of question, you can't beat the Operator's Manual. That's the one that has routine maintenance procedures. You can buy one in the store on this site or at www.binderbooks.com.
There is no dipstick. You'll see two petcocks on the left side of your oilpan. There's a quart's difference between the two. General rule is that if you open the lower one and get oil, you're fine. If you don't get oil out of the lower one, close it. Open the upper one and add oil until it flows out there, then close it, too. Now you're full.
Your filter is under the tall dome at the right rear of your motor. It looks like a nut on top, but it is a long hollow bolt holding everything down. The dome contains the replaceable filter element that comes (CaseNH, CaseIH dealer or NAPA are all good, easy sources) with a separate gasket. Only caution there is that the gasket (think of a square sided O-ring) likes to stick in the groove at the base of the housing, especially if it hasn't been changed in a while. Just make sure the old gasket is out before installing the new one and you won't have any trouble.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
