Posted by Owen Aaland on July 23, 2008 at 06:41:15 from (65.161.86.52):
In Reply to: Ok My turn to ask. posted by IaGary on July 23, 2008 at 05:45:53:
You have a leak somewhere between the fuel tank and the charge pump on the back of the injection pump. It may not be great enough to leak fuel but it draws in air when it is running. A tiny leak will not let in enough to have much affect on the engine when it is running because the pump is able to keep purging it back into the tank. When the engine is shut off the air collects in larger bubbles and when that gets in the pump it can cause the engine to die.
If you have not already done so, change the primary fuel filter. The primary filter has a vacuum cause by the charge pump drawing fuel through it from the tank. The secondary filter is under pressure from the charge pump and should not allow any air into the system. A dirty filter can cause the charge pump to create a larger than normal vacuum in the system which will draw in air at a poor connection. Inspect the fuel lines for any worn spots. A worn/cracked line may allow air in before you see it leak fuel. Tightening the fuel line fittings may help but there is good chance that the seal rings have gotten too hard to keep a good seal. If changing the filter makes no difference I would also install new seal rings.
Another possible leak location may be the charge pump itself. A worn hand pump seal could allow air to be drawn into the fuel system. A worn seal on the pump drive shaft usually causes fuel to enter the crankcase but it may be possible for air from inside the infection pump to be drawn past it.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
