Re: Suggestions for 560D coolant leak..UPDATE
Posted by Owen Aaland on July 23, 2008 at 06:58:26 from (65.161.86.52):
Clefus said: (quoted from post at 18:07:07 07/21/08) I finally got a free moment yesterday to pull the head....
......Funny this head gasket only lasted less than 100 hours ....It was done before I got the tractor...I noticed some valves werent IH..also..just replacements....
Premature failure of the head gasket can be caused by a warped cylinder head, a warped block, improper sleeve height, or failed head bolts.
A stretched bolt can still be brought up to torque but will have lost enough strength so that it does not have the proper clamping force. When that happens they allow the head to move up when there is a power stroke in the cylinder. Any bolts that were looser than others when you took it apart need to be examined very closely for this problem.
Adjust the valves to specs given for the hot setting. That is fine for anything above room temperature.
