With the TA lever back, does the tractor free wheel when slowing down? If so then you do not have hydraulic control to either clutch pack.
If you had the input shaft out of the clutch carriers, did the oil holes get lined up when the shaft was reassembled? Are the sealing rings in place on the input shaft? Did the jumper tubes get reinstalled?
Using a gasket as a pattern, I made a plate to bolt on the clutch housing with holes to be able to pressurize the jumper tubes to verify that the clutches are working. You can just apply air pressure to the high and low jumper tubes but be careful because the air pressure will blow them out. The plate just holds them in place for hands free operation.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
