Re: gas in oil pan
Posted by 36 coupe on July 24, 2008 at 05:06:59 from (64.136.26.226):
In Reply to: Re: gas in oil pan posted by mkirsch on July 23, 2008 at 18:37:12:
Ive had this happen in Ford and JD tractors.Gas gets by the rings and ends up in the crank case.Engine will crank but turns hard because of oil dilution.Engines with fuel pumps can let gas into crank case if the diaphragm leaks.most pumps will show outside gas leakage.Never say never when working on engines.Ive had a JD H run on with the gas line disconnected, not just 5 minutes but run on.The tractor had some gas dilution and was pulling fuel thru worn intake guides.
