Re: 4.125 bore Super MTA piston
Posted by kossuth on July 24, 2008 at 05:30:07 from (214.3.140.16):
In Reply to: 4.125 bore Super MTA piston posted by tj in iowa on July 23, 2008 at 19:38:56:
tj in iowa said: (quoted from post at 19:38:56 07/23/08) I believe 350 chevy pistons are the same bore, it you want to make it scream, some people have done this.
Not quite that easy though. You would need the proper connecting rods to do this as well depending on the piston pin location. Depending on the location of the piston pin you may have to clearance the bottom of the sleeve/bore for connecting rod clearance. Alot of variables on this one.
