Re: Farmall H tranny lube
Posted by Wayne in MN on July 24, 2008 at 06:11:15 from (68.119.27.241):
In Reply to: Farmall H tranny lube posted by Kevin Dangle on July 24, 2008 at 05:23:49:
Hy-tran will make it noisier yet!
Unless you plan to use it on a -40 snowy winter day, the heavier lube will be just fine. Even then you just need to let the clutch out SLOWLY to get things moving. BTDT many times.
