Posted by jal-SD on July 24, 2008 at 08:52:39 from (71.209.118.141):
In Reply to: Cub radiator removal posted by Michael Adams on July 24, 2008 at 08:29:20:
Yes, you will have to remove all the bolts that connect the casting to the radiator core, the casting is the lower radiator tank. Be careful with the pressure washer around the radiator, if its "tender", the pressure washer could wash holes in it, I'd think about not pressure washing until the radiator is at the shop. Good luck on getting all those bolts out with out twisting a few off. Start by soaking them with lots of penetrating oil for a couple of days (several times a day) before you try to take them out. As for the wiring, I re-wired mine, but did it one wire at a time. (I was too tight to buy a kit & didn't care about keeping it original.) I ran a separate ground wire for each light and ran them back to ground at the same location as the battery is grounded to the chasis. 6V is plenty of voltage for a Cub, but 6V does NOT conduct through rust as well as 12V will, hense the ground wire. Good luck, I just love my Cub. (My $0.02 worth. jal-SD)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
