Re: Farmall H 12v conversion problem
Posted by CNKS on July 24, 2008 at 18:12:51 from (216.144.104.128):
In Reply to: Farmall H 12v conversion problem posted by G-man49 on July 24, 2008 at 18:01:40:
Try this link, Bob got a different website a while back. If a generator it can be positive or negative, alternator must be negative ground. Some voltage regulators are designed for pos ground, will fail sooner if negative (not immediately). You need to polarize the generator, it should start. Wires to coil are reversed if changing from (+) to (-) ground, also to ammeter.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
