Re: Oil leak from under M
Posted by John M on July 25, 2008 at 03:55:45 from (209.213.22.170):
In Reply to: Oil leak from under M posted by tcanthonyii on July 24, 2008 at 20:16:53:
You have a few seals in the belly pump area, one for the pump, one rear engine seal, one for each transmission shaft. One of those is leaking.
