Some of these are TIMKEN and some are MRC. Timken owns Fafnir and some others and MRC is owned by SKF.
Now I did "upgrade" some of mine. For example on the pinion shaft I put in a 311M instead of 311. The "M" means a "Max Type" bearing (for timken that suffix is a "W") and has more balls and thus more load capacity with a small reduction in axial load capacity. I did the same for the outer axle bearings, using a 214WD. (I couldn't find a max type with one shield so I ordered one with two and removed one of the shields.)
The various suffixes will tell you if it's max type or if it has snap ring grooves or shields. You'll notice these as you take the old ones out. Go to SKF.com or Timken.com for their lists and explanations, tons of good info.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
