Thanks to each of you. I was going to borrow a pressure pump and test the pressure myself. Now I will not. The fellow at the radiator shop estimated as much as $300 to remove and clean the radiator and re-core it. I can buy a new one for just over half that. I think I will just remove it and rod it myself. Worst case is I need to buy a new one. I am wondering whether there is a leak because I do not see fluid when I look in the top of the radiator. It is probably worth filling it with half water and half antifreeze to see what happens - or... just put water in it and drain it after a while if there are no obvious leaks. Any thoughts on this plan??
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
