Re: Oil Leak in the underbelly of an H.
Posted by John - OH on July 25, 2008 at 19:27:47 from (74.5.130.31):
In Reply to: Oil Leak in the underbelly of an H. posted by Pairodox on July 25, 2008 at 17:49:54:
You can replace without splitting the tractor. Pull the cotter pins and slide the collars back, the hydraulic pump drive shaft will come out. Unscrew the coupler off the rear shaft. Remove the seal flange (3 bolts). Put the new seal in and put it all back together. Napa can get you the seal you need for about $8.00.
