Re: Oil Leak in the underbelly of an H.
Posted by JFavor on July 25, 2008 at 19:30:24 from (205.188.116.73):
In Reply to: Oil Leak in the underbelly of an H. posted by Pairodox on July 25, 2008 at 17:49:54:
Yes you can replace that seal. Remove the two cotter pins and slide the sleeves. The shaft will come out easily. Remove the bolt that holds the coupler on the transmision side. Standard, right thread. Once you slide the coupler off you can unbolt the housing the seal is in. The other shaft (from the clutch) has a seal also (on the transmision side). I'm sure it is leaking as well. This flange can be unbolted also but it's really tight. Both of these seals will need to be replaced. Good luck.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
