Are you 100% sure you have camshaft and fuel injection pump timed correctly. If I recall correctly the injection pump only turns 1 rev for every 2 revs of the crankshaft, so injection pump could be 180 degree out of phase or 1 rev out of time. You have to bleed fuel filters then injection pump, then crack a couple injector lines and crank engine. Also will not start unless glow plugs are working without a lot of cranking and outside temp is 90F or more.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
