Re: H points adjusting?
Posted by riverbend on July 25, 2008 at 20:57:07 from (208.160.33.104):
In Reply to: H points adjusting? posted by kwm219 on July 25, 2008 at 19:06:38:
The Operators Manual gives instructions for setting the points. Set the opening point to 0.020" gap when the rubbing block is on the lobe of the distributor cam. If the gap is not correct, loosen the screw on the fixed point and move it until the gap is correct after you have tightened the screw.
Two things to pay attention to:
1) make sure that the points meet squarely. It is possible to twist the moveable point when you tighten the nut that holds the spring.
2) you have to reset the timing.
Greg
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
