C negative ground
Posted by sams on July 26, 2008 at 04:06:37 from (68.10.42.3):
looked at a 1947 C, battery connected w/negative ground. I thought C"s & S C"s were pos. ground. Other than switching the battery cables, what other things should I check to make the change to positive ground?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
