The starters performance problem is NOT a function of Pos or Neg ground, either still turns it and the same direction, of course.
FIRST thing I would do is remove, clean n wire brush, n reattach each n every battery n starter n starter switch/solenoid n ground connection.
For 6 volt systems I recommend the use of 0 or better yet 00 gauge battery n starter n ground cables
Has the battery been Load tested?? Is it good n charged?? I recommend the biggest heaviest highest rated battery that will physically fit
It may well be a cable or connection problem CHECK THAT N DO AS POSTED ABOVE n make sure the battery is good n fully charged.
If you reverse battery polarity the genny should have been polarized or else the Voltage Regulator may have been damaged. Once you reconenct the battery be sure n Poalrize the genny BEFORE you start it.
For a Troubleshooting Procedure for Non Charging click on the URL link below
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
