Re: farmall cub engine knock
Posted by ezed76527 on July 26, 2008 at 07:11:45 from (199.3.116.5):
In Reply to: Re: farmall cub engine knock posted by dave guest on July 25, 2008 at 20:31:11:
I will pull the plug wires as you suggest. What about the idler gear between the crank and the ignition drive. Is it possible for the engine to knock if the idler gear bushing is worn? What about the governor? It does not sound like a rod or pin knock.
