Posted by Idaho Ron on July 26, 2008 at 10:03:06 from (208.98.173.2):
Well yesterday I was working on my Hydraulics on my Super C. I changed the oil seal on the top on the auxiliary control valve. Last time I messed up the seal, this time I got it right. I started to look over the hydraulic cylinder on the FH I had JUST rebuilt. I saw a leak! I thought it might be the hoses so I pulled them off and replaced them.
First thing that went bad. The small screws that hold the spool valve broke off. After that I got the hoses and put them on. I had the same leak. This time when I got to looking at it I found out I had over tightened the hose end and the head of the cylinder had a crack in it.
I took it apart and soldered it. I put it back on and it was still leaking. I took it back off and hit it again with solder. This time I it closer to the hole. I put a ¼ nipple in the hole while I was soldering it. I almost got it stuck but I did get it out. I got it on about 10:30 last night and tried it. Well I got the hoses backwards, but I think the leak is stopped. If it does it again I think I am going to put a short pipe nipple in it and solder it in.
Have any of you ever had that happen? How did you fix it and did it hold? Thanks Ron
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
