Posted by John T on July 26, 2008 at 10:17:58 from (66.244.97.31):
In Reply to: C Gen posted by henryv1111 on July 26, 2008 at 09:46:22:
Henry,
QUESTION: What does that reg do. Does it partialy ground the field.
ANSWER: Yes something like that butttttttt more precise n calibrated. It regulates the current throught the gennys Field windings by the addition or removal of resistance between the FLD post and ground (via the VR) akin to how the old fashioned Low/High charge light switch did by dead grounding the Field for max charge or adding the resistance in series between FLD and ground for Low charge. HOWEVER it also more finely regulates it by the opening n closing (something like duty cycle) the field control relay contacts between the ground and the resistance...
If the charging system n genny n light system are all okay it shouldnt go to dischaerge with lights on unless its running slowwwwww and/or theres a VR or some other problem. Run my Troubleshooting Procedure as needed to see what the problem is.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
