You need to check the gas flow to the carburetor. Unhook the gas line at the carb and see if there's a full stream of gas, no trickle. Hold a clean container to catch the gas. I would remove that in line filter if its not for a gravity flow system. If there's a full stream from the gas line remove that tube fitting from the carb and clean the screen behind the fitting. Have you opened the main jet adjustment screw near the bottom of the carb? This is where your engine gets the enriched fuel mixture. Hal PS: You need to check the timing to make sure its not retarded. Make sure there's no blockage in the radiator if its running hot. Need to find the cause before you crack your cylinder head or worse.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
