Re: NEED HELP ON 560D CLUTCH!!!!
Posted by the tractor vet on July 26, 2008 at 19:10:59 from (76.212.228.92):
In Reply to: NEED HELP ON 560D CLUTCH!!!! posted by arkie on July 26, 2008 at 18:18:09:
The damper springs of the disc face AWAY from the flywheel. The easy way of doing this job is to place the pressure plate on the shaft then place the disc on the shaft slide the tractor together then bolt the pressure plate to the flywheel this way you only have to align the pilot bearing to the shaft and you work thru the bottom to bolt up the pressure plate.
