Re: NEED HELP ON 560D CLUTCH!!!!
Posted by tn terry t on July 26, 2008 at 19:38:56 from (64.12.116.144):
In Reply to: NEED HELP ON 560D CLUTCH!!!! posted by Mike 50 on July 26, 2008 at 18:18:09:
arkie said: (quoted from post at 22:34:18 07/26/08) Throw out bearing has been replaced but the tractor is split and I haven't engaged clutch pedal to see.My problem is when I attach clutch with pressure plate the three fingers goes closer the more I tighten the pressure plate to the flywheel.
like i said in the above post the fingers moving closer is normal, put the thing together
