Hi, I resently purchased a SMD. It started hard and with a lot of black smoke, but it took a lot of cranking. I was new to the MD, so I first read and studied the shop manual. I decided to do everything I could first before taking anything apart. I found the Carb bowl had a lot of debree ,I then removed and cleaned Gas line and bowl. Removed screen at carb input, and it was full of debree. reinstalled and put measured amount of gum out in a full gas tank started and run it through till empty, repeated again. engine started better, but not smooth. Installed new points, dist. cap and wires, plugs looked near new. Engine would then start and run smooth after 6 to 8 turns and with little smoke. I pull choke out full for a couple of turns, push in and it starts a few turns later. Note: Always run on gas before shutting down, this cools the eng. and also burns out any remaining diesel. Don"t forget to throw the lever back to diesel after engine stops to cool starting valve seats. Brissco
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
