Re: Steering wheel removal on an H
Posted by TomH in PA on July 27, 2008 at 18:19:56 from (67.142.130.15):
In Reply to: Steering wheel removal on an H posted by Pairodox on July 27, 2008 at 17:28:50:
Find a torch, even a disposable MAPP outfit will loosen the nut. You'll still have a problem getting the steering wheel off the shaft. If you're planning on replacing the steering wheel anyway you can carefully grind through the hub.
