Here is what I have done, with excellent results. Heat one side of the nut with a torch until it is red hot, let it cool some, spray with penetrating oil or engine oil for that matter. The heat will draw the oil into the threads. Then with a socket and ratchet or an impact wrench remove the nut. Like Vito said, don't use a pipe wrench on the steering shaft, just turn the steering wheel all the way to the left and then you can wrench on the nut without the steering wheel turning. Best way to remove the steering wheel is with a gear puller and a torch to apply heat to the hub of the wheel to expand it and break rust bond. If you don't want to save the steering wheel and you are lacking a gear puller or torch, then just grind or cut through the hub then take a cold chisel and hammer it into the cut to expand the hub slightly. Finally you can take a hammer and big punch and knock the wheel off.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
