Re: 12 Volt Postive or Negative Grd. Which is best?
Posted by Gene Bender on July 27, 2008 at 19:51:03 from (67.55.226.165):
In Reply to: 12 Volt Postive or Negative Grd. Which is best? posted by lester350u on July 27, 2008 at 19:27:29:
12v gens are easy to find at tractor repair shops ect just make sure when you get a regulator for that gen you use the ground thats usually stamped on the underside as in thiose days both grounds were used. If you find an original 12v for I-H it will have a red Delco Remy tag. Those were neg ground. It is a good idea to get the regulator for that Delco# so it works better. The 12v thingy is without the biggest topic on this site.
