Re: 12 Volt Postive or Negative Grd. Which is best?
Posted by Bob on July 27, 2008 at 19:54:39 from (69.178.228.68):
In Reply to: 12 Volt Postive or Negative Grd. Which is best? posted by lester350u on July 27, 2008 at 19:27:29:
If you are going with 12 Volts, you may as well make it (-) ground.
This will save a LOT of confusion later with battery installation or charging, as well as jumnp-starting the tractor, or using it to jump-start something else.
