Re: H Hood not lining up right
Posted by glennster on July 28, 2008 at 05:35:06 from (75.57.91.65):
In Reply to: H Hood not lining up right posted by 160dan on July 27, 2008 at 18:44:46:
if after moving the radiator back and the fuel tank forward and you still dont have enough, you can try and loosen the frame rails up from the front bolster (support the tractor below the clutch housing to take the weight off the front end) and see if you can get the bolster back a little more, there is just a little wiggle room there, could be the bolster is tipped forward just a hair, this would cause the top gaps to be off also.
