A Generator will work fine at EITHER Pos or Neg ground but if you convert to an alternator Id go with Neg ground as most all except for special made require Neg ground.....If youre re doing it Id go with Neg ground n be done with it....
If you change Polarity the ammeter leads need swapped or else it would register bass ackwards. If wired right with the tractor setting not running if you turn on lights or ignition it should swing over to - discharge...
The coil is also polarity sensitive. With Neg ground its lil + terminal ought to receive ignition switched input voltage while its other lil - terminal wires to the distributor.....
Mske sure the VR matches your ground as some are labeled for Pos ground while others are for Neg ground.....
BE SURE TO POLARIZE THE GENERATOR BEFOREEEEEEEE YOU START HER UP...
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
