Re: Cutout or Regulator
Posted by ScottyHOMEy on July 28, 2008 at 06:36:46 from (71.241.202.190):
In Reply to: Cutout or Regulator posted by Greg-N-CA on July 28, 2008 at 06:00:04:
I'd think the first consideration is whether the tractor has a three- or four-position light switch. With the four-position, a cutout is what you need, since the voltage is regulated manually by selecting the Low or High charge positions of the switch (the Low position switches a resistor into the chage circuit). A three-position switch doesn't have that resistor and controls only the lights, so you would need a regulator in that case.
Not ashamed to say that I still learn something or other most days, and I'm not sure what difference there would be with a newer generator, so I'll be watching to see what that distinction might be.
