After cranking, pull a plug and see if it is "wet". Let us know this. When you have that plug out, put it back in the plug wire, clamp it to the frame rail, crank the engine and see if you have spark there. Let us know the results of these two tests.
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the
... [Read Article]
Latest Ad:
[More Ads]
