Drain the fuel and put in new fuel. Make sure your sediment bowl, tank and fuel lines are clean. I'm guessing you might have a dirty/gummed carburetor or a stuck needle/seat or float. If it has a good blue spark to the plugs, it is probably a carb problem. Since it has sat for a year, it would be a good idea to take off the carb, clean it with carb cleaner and compressed air, and put in a new rebuild kit (YT sells new kits). If you do not have spark to the plugs, take apart your magneto or distributor (which ever you have) and check the points, clean any junk off the points, they MUST be very clean. Also make sure that the points gap is set correctly. If you still don't get a spark, but a ignition tune up kit that has new points, condenser, and rotor. If it still does not have spark with these parts put in, the coil may be bad or if you have a magneto, the magnets may need to be re-charged. Make sure that your spark plugs and wires are in good condition too.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
