Re: Questions about Farmall H pistons and head
Posted by Andy Motteberg on July 28, 2008 at 17:39:40 from (4.143.220.17):
In Reply to: Questions about Farmall H pistons and head posted by MAC in TX on July 28, 2008 at 12:26:11:
The magneto will work fine, no problem, but you should have a 12 volt system if you don't already, a 6V won't crank a high compression engine very fast and may not crank at all in cold winters.
