Re: IH 766 Clutch Problem
Posted by mazemeister on July 28, 2008 at 17:55:30 from (24.188.81.230):
In Reply to: IH 766 Clutch Problem posted by sqk on July 28, 2008 at 12:27:54:
one other possibility that hasn't been mentioned- this happened on our 986- if the cushion springs in the clutch disc self-destruct, then you'd lose transmission but not pto and hyd. the outer part of the clutch disc would be driven as normal, but not the spline in the center.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
