Michael, tools required, 3/8" or 7/16" socket, 2 lengths of about 2 to 3Ft of clear plastic tubing that will fit on bleed screw nipple and a clean hydraulic fluid container. Method, run tractor until hydraulic fluid is up to temperature, park on level surface, lock parking brake and block rear wheels, with tractor running at low idle open bleed screws on top of axles and connect clear plastic tubing to bleed screw and put other end into clean container, rest container on top of drawbar, speed tractor to fast idle (1500 RPM) and let hydraulic fluid flow thru clear tubing until there are no air bubbles, then close bleed screw. DO NOT PUMP BRAKES. Top up hydraulic fluid reservoir with fluid from container. If brakes are really bad then may have to repeat in a day or so to get all the air out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
