Re: Farmall Regular Timing
Posted by KEB1 on July 28, 2008 at 19:28:13 from (63.227.127.241):
In Reply to: Farmall Regular Timing posted by Kuzma on July 28, 2008 at 18:24:51:
Don't see my manual at the moment, but this will get you close enough for it to run.
Remove the spark plug from #1 cylinder & bring the engine around to #1 top dead center on the compression stroke. I believe there's a timing mark, but I just watched the top of the piston through the spark plug hole to find TDC. You could also use a piece of wire as a feeler.
Rotate the magneto so that the rotor is pointing at the #1 contact and the points are just opening. Connect the coupler on the magneto shaft in this position.
Set the impulse and turn the engine over until #1 comes up on compression again. The impulse should trip slightly after top dead center. If it doesn't, adjust the position of the coupler until it does. If it trips before TDC, the engine will kick back.
To adjust the coupler, remove the two bolts holding the halves together, rotate the magneto side in the appropriate direction, and put the bolts back in whatever pair of holes lines up.
Keith
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
