Posted by Janicholson on July 29, 2008 at 06:56:34 from (199.17.6.122):
In Reply to: mw pump on m posted by I.H.parkingonly on July 29, 2008 at 04:50:52:
Probably just a seal/"O"ring at that end. There are no kits I am aware of, but someone may supply a positive answer. The seals and/or rings will be garden variety Chicago Rawhide, or National component. If the pump is still making good pressure, The seal is going to fix it. If there is a groove worn in the shaft, it will be necessary to use a speedy sleeve. The "O"ring bore may need to be enlarged to accomodate the sleeve. The use of Teflon based "O"rings is also a good idea if available. Take pictures of things while disassembling. Be clean, place parts in order on a (used) lint free towel. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
