Re: sleeve pulled
Posted by El Toro on July 29, 2008 at 07:50:07 from (64.12.116.73):
In Reply to: sleeve pulled posted by :RIVIR on July 29, 2008 at 07:32:36:
third party image
They fit pretty snug in the block and you will need a puller like Keith made or if the block is off the tractor have your local auto machine shop to press them out. Hal
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
