Re: Mag to Dist. conversion
Posted by Gene Bender on July 29, 2008 at 07:51:29 from (67.55.226.165):
In Reply to: Mag to Dist. conversion posted by labman98 on July 29, 2008 at 07:36:06:
You dont need to change the plug wires. You should be able to find a dist at a salvage yd i would go with the I-H dist. The DELCO-REMY sits vertical. If you have the live hy pump then you need the upright so it will clear the oil filter.
