Re: Mag to Dist. conversion
Posted by El Toro on July 29, 2008 at 07:59:50 from (64.12.116.73):
In Reply to: Mag to Dist. conversion posted by labman98 on July 29, 2008 at 07:36:06:
You will need an ignition switch so you can feed battery voltage to the coil and distributor. Voltage needs to be fed to the switch too. Whenever you decide to change you need to note where the rotor is pointing on the mag before you pull it and then DON'T move the engine. Turn the rotor on the distributor to where the mag's rotor was pointing. It would better to make a little sketch where the mag's rotor is pointing so you don't forget. Hal
