Re: 1456 tractors
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by medfarm on March 18, 2000 at 18:35:31 from (209.162.22.189):
In Reply to: 1456 tractors posted by Farmall 1456 on March 18, 2000 at 17:15:32:
I do not have a 1456 but I do have a Farmall 1566. It is a 1977 model and I believe it is the last and biggest Farmall (IH) tractor. The tractor dynos about 160 HP. I use it for heavy tilling and pulling a 24' tandem finishing disc for preparation of grain crops. The engine revs very high and you can listen to the turbo whine all nite long. The tractor is a 3 speed with a high/low and a torque amplifier. The air conditioning does not work so I open the side windows. We rebuilt the engine 4 years ago and the rear end 5 years ago. The tractor is cabable of doing a lot of work with a value of 50% of an equivalent John Deere.
Post A Followup
: Re: Re: 1456 tractors
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
