Posted by Pairodox on July 29, 2008 at 17:05:48 from (71.161.245.208):
I'd like to spiffy up the 3 hydraulic ports on my H. I'm working on the transmission and hydraulic shafts at the moment and so have the belly open. I can see these tubes where they emerge from the pump. Question is .. if I remove these supply lines and clean them up will I regret that I did so because of leaks after replacing them? Will I have to drain the hydraulic oil if I decide to go ahead?
Also .. when working on the shafts I mentioned above I drained all the transmission fluid from the machine. There was about 8 quarts of BLACK, THICK stuff - nasty. It's probably more than 60 years old. What should I replace this with?
Thanks in advance. More questions to come when I dream them up!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
