Re: 574D fuel filters
Posted by JimB2 on July 29, 2008 at 17:35:04 from (99.241.179.24):
In Reply to: 574D fuel filters posted by cb-btf on July 29, 2008 at 07:07:58:
CB, there was about 3 different filters types used on the D-239 engine. Caseih parts D-239 shows the different types. I believe you would have to purchase a new filter head and possibly do some fuel line mods.
BTW make sure there is no old bits of "O" ring stuck in the filter head grooves and do not over tightened the filter bolt or you will distort the gaskets.
JimB
