power loss (cutting out under load)
Posted by matt dehn on July 29, 2008 at 18:34:26 from (72.204.85.68):
my cub lo boy (late 50s model) cuts out under a load to the point where mowing is not possible-- so far i have replaced the points condenser, checked fuel flow to carb, new float in carb, checked timing, dwell, and compression. replaced plugs and wires. checked air cleaner system, tried running without aircleaner, new carb float, checked for intake and carb air leaks- nothing seems to work-- any ideas?-- one other thing- when it starts to die, if you cut back on the throttle it seems to recover a little- oh yeah govenor is working ok. ?????????
