Re: farmall h carburator
Posted by Andy Motteberg on July 30, 2008 at 14:43:08 from (4.143.218.249):
In Reply to: farmall h carburator posted by daytonfarmer on July 30, 2008 at 08:28:06:
It is not a common problem for a H carb to leak. It will not leak if you have everything as it should be on the carburetor, you don't need an in-line fuel filter, they will cause even more problems. Make sure your carburetor float level is correctly set and be sure the float is in good condition. Make sure that the needle and seat are clean and moving freely. Make sure you have a good bowl gasket and good packing in the adjustment screw on the bottom of the carb. It could also be that your carb adjustments are not right and it is flooding out. (getting too much gas). Also shut off the fuel supply under the fuel tank when the tractor is not running.
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
