Re: c-135 engine
Posted by El Toro on July 31, 2008 at 07:16:40 from (64.12.116.73):
In Reply to: c-135 engine posted by craigreavley on July 31, 2008 at 06:46:50:
Have you soaked the pistons with ATF? You can free up that engine with a lot of patience. You're probably need to rebuild this engine anyway
so I would pull the engine. Pull the head and oil pan and loosen the rod nuts. Remove one of the rod caps and use a piece of 2X2 oak and a big hammer and drive the piston out. The sleeve may come out when doing this, but with heat from an acetylene torch you can free the piston and be able to reuse the rod. You can always take the block to your local auto machine shop and have them pressed out. Your block probably needs to be cleaned of any dirt or sludge. I think those are wet sleeves and they're not pressed into the block so they should come out with a little effort. The area where the sleeve seals are needs to be cleaned too. Rust and dirt gather in that area and may cause an overheating problem.
Take a lot of pictures and notes and make sketches
too. They will be a big help during the rebuild.
Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
